It is currently Sun Aug 24, 2025 5:39 pm
PostPosted: Tue Aug 13, 2013 8:13 am
Perhaps someone can help me. I recently saw a video clip on making/installing radial purfling in a thread. I thought, "this is a great little tutorial. I'll have to refer to it when I decide to do radial purfling." Now I am d-----d if I can find it! Can anyone point me to it?
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Aug 13, 2013 8:35 am
First name: steve
Last Name: barbour
Country: U.S.
viewtopic.php?f=10117&t=35809 I think this is what your looking for
Kyle
PostPosted: Tue Aug 13, 2013 9:20 am
Thanks, Todd et al. That is exactly what I was looking for. Now, where'd I put those glasses?
Max Bishop
Brighton, Michigan
PostPosted: Tue Aug 13, 2013 10:33 am
Or, with some woods, you can just make a log, cut strips and bend to fit. Install like regular purfling.
Log glued up.
Gluing boarder strips to one edge.
Cut large strip.
Glue boarder strips to other side, cut into purfling layup strips.
Bend strips with binding, or bend separately as I did. Bent on hot pipe. No problems.
Install.
It is possible that some woods may not work as well this way.
PostPosted: Tue Aug 13, 2013 10:35 am
Couldn't make that duplicate go away. Sorry!
PostPosted: Tue Aug 13, 2013 12:39 pm
Thanks, Waddy. That is really beautiful.
Max
Max Bishop
Brighton, Michigan
PostPosted: Wed Aug 14, 2013 11:00 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Waddy like the look ?? Thanks for posting
PostPosted: Wed Aug 14, 2013 2:05 pm
In the cabinet maker's world that's called 'cross banding'. I use cross band backgrounds in my braid rosettes. It's interesting because it reflects the light at a different angle than the braid, so that, when one is 'light' the other is 'dark'.
PostPosted: Wed Aug 14, 2013 6:48 pm
Last Name: Beaver
City: Lake Forest
Todd, Chris,
Beautiful job!!! What did you use for the radial?
Joe Beaver
Maker of Sawdust
PostPosted: Wed Aug 14, 2013 9:48 pm
Last Name: Beaver
City: Lake Forest
Thanks guys. They are both outstanding !!!
Joe Beaver
Maker of Sawdust
PostPosted: Thu Aug 15, 2013 5:31 am
First name: Trevor
Last Name: Gore
City: Sydney
Here's another take on the radial purfs. This one is just EIR from side off-cuts. Construction is like inlaying shell using the plastic removable strip method. However, the glue used is Titebond. No matter what I try, the white purf line goes yellow if even a sniff of CA wafts in its direction. Thin the Titebond with water just a little bit, drop in a full length of side off-cut "on the straight" just below the waist and slide it around to where it's needs. Mostly it won't break as it goes around the bends, but it doesn't matter if it does. The break will be invisible, anyway. Cut the purfs after you've made the channel. Getting the width EXACTLY right (think Goldilocks) is the difference between a job that's a real pleasure and one that's a PITA.
http://www.goreguitars.com.au
PostPosted: Thu Aug 15, 2013 7:24 am
Beautiful stuff, everyone. Can't wait to try it on my next guitar.
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Aug 15, 2013 9:22 am
Trevor, you might try thinned fish glue. I find it to be excellent for flooding rosettes when I inlay them.
PostPosted: Thu Aug 15, 2013 1:13 pm
Last Name: Beaver
City: Lake Forest
Great stuff all!!! I've been inspired to give it a try.
I'm leaning toward the dark side myself. Todd's cocobolo, Trevor's EIR, or Filippo’s ebony.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Aug 15, 2013 1:43 pm
First name: Wendy
Last Name: W
State: Arizona
All very inspiring! Filippo, I'd love to see a front shot of that with the rosette!
Wendy
PostPosted: Thu Aug 15, 2013 5:16 pm
That is a stunner, Filippo.
Users browsing this forum: ThomLuth and 9 guests
